We are having a system which is no longer serviced by the installing contractor and no one knows the admin password.
Any suggestion?
Thank you
Can NFS-3020/30 be defaulted to factory password settings?
Re: Can NFS-3020/30 be defaulted to factory password setting
rondparker wrote:We are having a system which is no longer serviced by the installing contractor and no one knows the admin password.
Any suggestion?
Thank you
hi, try to sent a password release letter to the regional sales of notifier (not from your alarm company)signed in from the owner of the building, i did this on the past with no problems.
regards...
00000-admin default,11111-user default
hi all..
anybody help me give copies verifire tools for nfs2-3030 ?
thanks,
thanks,
Notifier will release the code to the customer put not the alarm company.
attached are the docs needed.
notifierpasswordagreement
do you have software key?
thanks
thanks
I do not think notifiers newest software uses a software key.
I heard that you need to send your laptop to notifier to get the software install as an added security measure.
that is what a notifier tech told me.
If the 3030 can be hand programmed have the customer get the code?
Hi since verifire tools 5.9 the software need a hasp key to download the program, you can use 5.7 if the panel is not upgraded with above software version.Leo wrote:I do not think notifiers newest software uses a software key.
Regards.
I you had the admin or highest level code would you be able to program the panel via the display or is the program a must?
Hi Leo,you are right all notifier panels can be program from the display, even with the software you need to know the admin password.Leo wrote:I you had the admin or highest level code would you be able to program the panel via the display or is the program a must?
Happy New year to all members.
