I am using an NFS2-3030D DB ver 25, What range of LCM-320 cards will work with it? I bought an LCM 3.03 and I am having problems, I would like to know the correct card ver before buying a replacement.
Thanks.
NFS2-3030 LCM versions
Re: NFS2-3030 LCM versions
not an easy answer.
if you are replacing a bad board try swapping the ROM chips
I had a problem like this a ways back.
I had to bought a PROM burner.
I got it working, just needed to update the CPU to V27
