Notifier Panel Password Lost 1010,2020,3030,640,320
rajesh
EST Database
Post by rajesh »
I lost my .SDU file . How can i get the details. I have fireworks graphic software
"Lost Password"
default programming Password all zeros: 00000000
Notifier stores the password for the panel in the panel not in the software.
If the password is Lost or unknown it needs to be recovered.
this can be done by contacting Notifier with the error code that displays when a incorrect password is entered.
The customer "not the alarm company" needs to send a letter to Notifier with error code, Notifier will call the customer with the code
Panel's password is stored in panel: AFP-200,320,640,1010,2020,3030,NCA
the older panels "AFP-200,1010,2020" can be found by a few forum users if you post the panel type and error code someone will help.
the newer panels "320,640,3030,NCA" ONLY Notifier can get the panel code via the error code.
again "ONLY NOTIFER CAN GET YOU THE PANEL CODES"
Verifire Tools is the software used to program the ONYX Series panels "NFS-320, NFS-640,NFS-3030"
Verifire Tools can not help you with finding the panel password
Via Verifire Tools without the password the panel can be uploaded, but not downloaded
if the panel is replaced it can now be downloaded, but you are replacing the panel or panels
yipsalani
Re: Notifier Panel PasI sword Lost 1010,2020,3030,640,320
Post by yipsalani »
I would like more information.. I need to recover a passcode for our demo unit. Someone changed it.
lava57698
Re: Notifier Panel Password Lost 1010,2020,3030,640,320
Post by lava57698 »
We have forgotten the master password for Notifier NFS2 - 3030 fire alarm control panel.
In option Program Alter/Status Menu, default Master password “00000000” typed and get result as Invalid password “4ADF-59BC-4686-9D52-699C”.
desertfire
Post by desertfire »
me too same issue forgotten password NFS-320 panel error code A8DF-7567-620D-A5E8-08FA
any one can give the password much appreciated thanks.
FVILLA
Post by FVILLA »
desertfire wrote:me too same issue forgotten password NFS-320 panel error code A8DF-7567-620D-A5E8-08FA
PM sent
TECH - Denver
Post by TECH - Denver »
Leo is correct, the only way to decode the hex code given by an Onyx series panel when an incorrect password is entered is to call Notifier directly, or call your local Notifier ESD and they can assist you with getting in touch with tech support to have the process started. It involves a bit of paperwork, affidavit signature, and I believe a notary must be used.
Another option is to call the installing company, request that they reset the default password, you might get lucky.
zhong
Post by zhong »
We have forgotten the master password for Notifier 3030 fire alarm control panel.
In option Alter Status Menu, default password “00000000” typed and get result as Invalid password “31C8-61C1-9DB9-4E69-37D3”.
thank you
FVILLA
Post by FVILLA »
zhong wrote:We have forgotten the master password for Notifier 3030 fire alarm control panel.
thank you
PM sent.
kittak
Post by kittak »
me too same issue forgotten password NFS-320 panel error code 324B-3B8B-30A3-13DD-15A5
