Entrapass Ver 4.04 is needed if you are running Windows7
it will also work with 32/64 bit processors
If running 3.18 or older you will need to buy the upgrade.
Note: some 3.18 will not need to be upgraded if bought after January 2007. the only way to know if the upgrade is not needed, is to try upgrading to 4.04, if it works then you did not need it.
Kantech - Windows7 Entrapass 4.04
Re: Kantech - Windows7 Entrapass 4.04
I am new to this field and I have an office that is using Entrapass 4.04 and I need to move the application to a new computer. Can you tell me where I can find this software version?
keep the old computer
call an access computer (I worked for ADT/Tyco) they maybe able to help
if you can get this to work, you da man
good luck
kantech is not cheap, maybe install a whole new system
good luck
