Kantech - System Registration/Software Register
Posted: Mon Aug 16, 2010 9:34 am
Notice to Installers
Read the following instructions carefully before you install, register or upgrade the EntraPass
application. For more details about installation, refer to the corresponding Reference Manual.
To install or upgrade the EntraPass application:
1 Insert the software CD-ROM in the CD drive. Select the Setup icon.
• If you are installing a new system, enter the Serial number (located in the CD-ROM pocket), then press OK. The OK button is enabled only when you have entered a valid Serial number.
• If you are upgrading an existing system, enter the Upgrade Serial Number written on the certificate, then enter the Registration Confirmation Code. The OK button is enabled only when you have entered both numbers.
NOTE: A database backup will be automatically performed during the upgrade process.
2 To obtain the Registration Confirmation Code you may:
• Call Kantech Customer support service at 1(450) 444-2030 or 1 888 222-1560 (US & Canada).
• For other countries or regions, consult our Web site (http://www.kantech.com) to find your customer support center.
3 Follow the instructions that appear on screen. At the end of the installation, you have to restart your computer.
To register the system (for EntraPass Corporate and Global Editions only)
1 Click the Server icon on the computer desktop. In the Server main window, click the Login/Logout icon.
2 Enter the 20-character password in the Operator login screen. The OK button is enabled when you have entered the correct password.
3 In the System Registration screen, click the Temporary password in use (...) (yellow button) to register the system. Enter the Registration Confirmation Code to activate your system. The OK button is enabled when you have entered the correct Registration Confirmation Code.
4 To obtain the system Registration Confirmation Code you may:
5 Use the Installation Codes displayed in the System Registration window and your original CD to install the system’s basic components.
6 Use the Backup utility to save your system data before you update or configure the system database.
