Quickstart Panel Trouble
SGJosh1
Post by SGJosh1 »
Hello everyone, I have a Quickstart that ended up having a bad CPU (CPU-2)...replaced it and uploaded the database. Now I have a trouble that reads Card 01 Unconfigured Device and when I go to the status it shows it as device 1-255 basically. How on earth am I going to find this if there really is a device out there that had been changed since the database was backed up??? Any help or suggestions are appreciated! Thank you.
Josh
zuckman1
Re: Quickstart Panel Trouble
Post by zuckman1 »
Not to be a wise ass, Josh, but did you Downlaod the CU to the panel or Upload the blank database to your laptop? once you send down the existing database and the panel starts up, you can compare the existing devices with the new Unconfigured Device, then locate the device in the building, accept it in the CU give it a message and download.
