Hello,
Just wondering if it is possible to add an annunciator to a quickstart panel from the front panel programming? the panel is already installed and working, but the customer is now renovating and was told by the AHJ that they need to add an annunciator. We have a used annunciator from a quickstart panel and would like to install it but need to know if it can be easily programmed into the system or if it will automatically recognize the new annunciator?
Thanks for your help in advance.
Adding an Annunciator?
Re: Adding an Annunciator?
you will need to use the QS program to add the annunciator
thanks for the quick response. will the software run okay on a windows 8 laptop?
Depend on my Experience This QS Software Compatible With Window Xp-3 and Lower
You'll probably need codeloader, too. Just to make sure all CPUs have the same microcodes.
