.Signature Smoke wired as a 2 wire smoke
The Signature smoke (siga-PS/PHS) can be used as a 2 wire smoke.
Found this by accident, a contractor wired a siga-PH to a hard wire zone and it just worked.
So I called EST and he said it would work, but that is all he said, he had no paper work to read.
CANTECH
Re: .Signature Smoke wired as a 2 wire smoke
Post by CANTECH »
Yes they work, but they are not listed for that application.
It is a nice feature when you do a panel transfer and are replacing the detectors. But on paper it is not officially working.
Beware
Chanwh898
Re: Signature Smoke wired as a 2 wire smoke
Post by Chanwh898 »
Yes, the detector should work like in standalone mode, where power is available but no communication with the loop card.
gururaja20
Post by gururaja20 »
Dear Friend,
I cant understand your explanation, could you explain the same
There are two types of smoke detectors (intelligent / hardwired)
The siga-PS/PHS are intelligent devices they communicate on a SLC line.
by accident I found that the siga-PS/PHS will also work as a hardwired 2 wire smoke detector.
