Re: Toggle command
Posted: Sun Mar 18, 2012 12:22 am
Interlock looks like it was made for what you are looking for.
config->cabinet->object config->operator layer->LRMconfig (change to interlock)
I have never used the interlock, looking at it now I should have used it in a few locations.
I can not call tech support about this for you and I have no clue how to program 2-3 switches to interlock.
Switch Type:Interlock designates that the switch operates as a 3-gang interlock switch.
When all three switches are in the restored (open) position, pressing a switch activates (closes) that switch. Pressing either of the two remaining switches, activates that switch and restores the already active switch. Pressing an active switch a second time restores the switch and leaves the two remaining switches in the restored position
