walk test in Est-3
Fireworks
Re: walk test in Est-3
Post by Fireworks »
There is no automatically created walktest in EST3, it has to be programmed in.
With the project opened goto menu "Configure"/"Objects"
Select the devices that you want to creat a response for.
Select "Service"/"Create New Group" - (Label your group to something meaningful if you are creating more than one group, example "SG1"), then select "Add Devices"
Got to "Rules" and "Edit Rules" and enter your rule:
[SG1]
SG 'SG1' : on Visible '*',
DLYR 5;
Tested on a stand alone using microcode 3.70 and SDU version 3.74
note on networked systems the DLYR will need to be longer to insure time to turn on/off.
To active walktest from the panel select "Menu" 8 then 1(start test) Select "SG1" then enter level 4 password.
peter
walk test in Est-3
Post by peter »
How I can program walk test in Est3. When I select on panel doesn't activate walk test. I can't find in program this setup. Thx.
