EST3 Rules-Disabling AMP via SWITCHES
Turn the amp on without a priority then disable the evac message to amps With a -HIGH
- Turn the evac message off high
[SW1 EVAC MESSAGE OFF] SW 'SW1' : OFF AMPOFF 'ZA20_AMP' TO 'Ch_Evac_01_08';
[SW1 EVAC MESSAGE OFF] SW 'SW1' : OFF -HIGH AMPOFF 'ZA20_AMP' TO 'Ch_Evac_01_08';
ALSO Check box: Re-evaluate SET Priorities on Restore
Configure->project parameters->operations->Re-evaluate SET Priorities on Restore
Note: by default SWITCHES turn on/off/disable with a -HIGH
[SW 1-1-2 SPKS OFF] SW 'PANEL1_SW1' : OFF '*SPEAKER*';
IS THE SAME AS
[SW 1-1-2 SPKS OFF] SW 'PANEL1_SW1' : OFF -HIGH '*SPEAKER*';
pooriyasms
Re: EST3 Rules-Disabling AMP via SWITCHES
Post by pooriyasms »
hi
is it possible to turn off an alarm which is connected to a CC1 via a switch(SW)?
and also is it possible to eliminate the delay (DLYA) for an alarm which is connected to a CC1 via a switch(SW)?
