Thanks to all in advance.
After recovered data from broken HDD, I got error message when i try to edit rules.
"file exceeds maximum size. error loading file."
Everything is fine except this problem.
DATA IS 171KB. (11 EST3 FACP interconnected)
I had no problem before with old XP computer.
I do not know what version 3-SDU i used.
Now I got the new computer and installed 3-SDU 5.02.
Different SDU version could be issue?
Thank u.
Edit rules problem. size of data too big?
Re: Edit rules problem. size of data too big?
the default text editor for the SDU is notepad, change it to wordpad or
try this editor http://www.thealarmtech.com/forum/viewt ... f=33&t=107
I can open PROJRULE.TXT with notepad.
but i can not open "edit rules" in the 3-SDU.
did you try changing the editor in the SDU to wordpad or something?
it sounds like the editor program the SDU is pointing at is bad, bad program, bad location
Really really Thank you LEO. I fixed problem. i just changed option as you said.
