rules for other panel
briac
Re: rules for other panel
Post by briac »
anyone please,
regards,
Nirujan
Post by Nirujan »
what kind of relay, is that CR module, and send me your SDU file..
briac
Post by briac »
hi,
thanks for your support Nirujan but I've sent my SDU to UTC canada then the told me but the SIGA CR is faulty,
I will proced to the changes of this CR and let you know later.
thanks again,
I worked on a system that had 30 panels and one of the panels (26 or 27) some of the outputs would not turn on.
there was nothing wrong with the rules we needed to write rules just for that panel outside of the commands files that were being used.
left the site before finding the problem.
we were sure the problem was in the SDU problem, not the hardware or rules
briac
Post by briac »
all,
I'v made the same simulation on two another panel in the same network,but no way,no activation,niente,
actually I built two panel in FO network, and I will try multiple configuration;
briac
Post by briac »
hi all,
did you heard about rulesidverify 14011?
this small application will verify your rules if it is more that the capacity of the SDU.
I will come back later for more explaination.
regards,
Leo wrote:I worked on a system that had 30 panels and one of the panels (26 or 27) some of the outputs would not turn on.
briac
Post by briac »
hi all ,
I have 49 panel in FO network,
on the panel #10 I have and group which sould activate a relay on the panel #27 and report on the LED of the panel #01.
my rules is like this:
"[and group on P 10]
ALARM ' AND PANEL 10FLAME DETECTOR':
ON LOW 'PANEL 01 AUD CIRC 05',
ON LOW 'PANEL 10 AND GROUP LED',
ON LOW 'PANEL 10 AUD CIRCUIT 04',
ON LOW 'PANEL 27 RLY STOP CONVEYOR';"
But the panel 27 relay never activated.
someone can help on that?
