FireWorks - Release notes 1.6
http://www.thealarmtech.com/download/ES ... eNotes.rtf - it's 20megabit, it may take a minute
What’s new in FireWorks 1.60.01
• iO64 and iO500 system connectivity via TCP/IP
• MN-NETRLY4 support
• MN-FVPN input/output zone support
• Support for new FW-UL5 and PCWD3 Watchdog Card
• Change from structured storage to a much faster SQL database
• “Redundancy” error correction
• Web Client:
- From Internet Information Systems (IIS)-based to Windows Communication Foundation (WCF)-based .NET Framework
- Increased from 5 to 15 concurrent user connections
- Filtering and sound options per client added
- Significant operational enhancements to Web Client operation
- Corrected Web Client dropping offline
• Local mode operation support
• Faster program startup
• Enhanced file backup utilities
• New PIN entry utility
• Enhanced e-mail format and operation
• Improved 3-SDU Gateway files import
• Enhanced graphic and AutoCAD file handling
• Correction of memory leaks and other issues that have been found since the release of FireWorks V1.50.
• OS/2 conversion removed
• Command passing between nodes
• Receiver Configuration Manager (RCM) enhancements
