Re: To clear troubles from Trouble/Disabled LED (queue)
Posted: Mon Dec 21, 2009 9:26 am
by mikbz
Hi sarian,
you have 2 options. I prefer the second.
the first option:
you should edit you export file *.oxp
in this file change 0* to 1* (1 is mean the not message in the fireworks).
the second option:
if you use SDU3.61 try import you project to SDU3.7 or greater. create transfer files from SDU3.7x and update fireworks.
(the SDU3.7x will repair you problem).
this what I do.
Posted: Mon Dec 21, 2009 10:49 pm
I think the main problem is the Map Fault is still in trouble,
You are masking the trouble.
Upload the map, check Loop Statistics, you will be able to fix the map fault.
everyone who has worked on the EST3 has had map faults that would not clear.
check this post -
http://www.thealarmtech.com/forum/viewt ... ?f=5&t=326
Posted: Tue Dec 22, 2009 3:00 am
by sarian
Thanks Leo,
I have tried several times to find the map fault in Loop Statistics, but there is no mismatch between Actual vs Expected data.
Posted: Tue Dec 22, 2009 7:14 pm
I have this one site I need to initialize the card via Map Static all the time to fix a (map faults) problem.
It resets the SDDC cards memory and starts over, It takes around 20 minutes to restart.
it seems to work and I have no clue whats wrong and why it works.
Posted: Thu Dec 24, 2009 9:38 am
by sarian
Thanks Mikbz!
Posted: Sat Aug 03, 2019 8:49 am
by dadishere
run the MFT tool or the HDT tool. sounds like a bad device/s out in the field
Posted: Mon Dec 21, 2009 7:32 am
by sarian
I have an EST3 FACP and there were some map faults in the system, when I downloaded the system again, all the map faults went out, except one. I think the remained map fault is because of defective wiring.
To clear the remained map faut, I went to Configure>Object menu and assigned Map Fault DataCard1 "Routing Label" and "Alt Routing Label" to NO CABINETS and then no map fault message is shown on the panel LCD.
The problem is that map fault message is still shown in the Fireworks Trouble/Disabled LED, how can I remove it?
Thanks,
Reza
