EST3/Fireworks
RogerB
EST3/Fireworks
Post by RogerB »
EST3 shows "Aux Port 1" trouble. I have MN-Com1s connected to port one, from MN-COM1S a cat5 to NIC card on FW PC . The MN-COM1S is configured correctly, I can also ping it from FW PC. What's the solution?
Jay
Re: EST3/Fireworks
Post by Jay »
Try using MN-NETSW1, you need a managed switch when connecting MN-COM1S to Fireworks. We've experienced the same and when we installed MN-NETSW1 it worked. Hope this helps.
shashishashu
Re: EST3/Fireworks
Post by shashishashu »
Check the event on a hyperterminal or putty when you press reset button or any event to make sure you are getting the data.
lucky_du
Re: EST3/Fireworks
Post by lucky_du »
I have many kind of dongles, such as EST(SDU, FireWorks),SIMPLEX,NOTIFIER,SIEMENS,etc..
All dongles can be test through internet,using sharing software.
If interested ,contact me 1679570458@qq.com
