HOW TO CONNECT TO A NETAXS-123
GAETEN
Post by GAETEN »
To connect directlly to a NETAXS-123:
That connection is call panel Web Base:
First way:
HTTPS://192.168.1.150 ( You have to put you network card on the same range to be able to connect on the default panel IP Address )
USER: admin
P/W: admin
The second way, you have to use the USB cable that came with the NETAXS123, so to connect directlly to the panel you have to do:
HTTPS://192.168.2.150 ( You have to put you network card on the same range to be able to connect on the default panel IP Address )
User: admin
P/W: admin
IMPORTANT NOTE: ALLWAYS ALLOW FEW SECOND AT THE BEGINING SO THE PANEL WEB APPLICATION GO ONLINE
