2 Major Issues Winpak Pro International 4 (Build 492)
dylanfree
Post by dylanfree »
Hello all!
New to the forum, so any help you can give me with this emergency issue is appreciated!
Our main server crashed and I managed to get it back online - however our software (after 3 years running perfectly) went into Demo mode.
Now I cannot add/delete users, etc. which is a huge problem as we have a wealth of new starters! Also, we cannot afford to buy an entire new set of software....
Is there a way to delete the license key and re-enter our original key? I have looked everywhere in the registry and cannot find anything!
Also, our SQL server was corrupted and I restored the WINPAK database to it -
Now card reads are not showing up and all of our Door Controllers are greyed out and the actual readers/doors are marked with question marks reading Output or Entrance Unknown?
I am concerned we are simply running off of what is stored in the door controllers/readers....
Does anyone have any insight into these issues?
I truly appreciate any help you can provide me here.
Cheers!
Re: 2 Major Issues Winpak Pro International 4 (Build 492)
you will need to register the program to get it out of demo mode
You will need the user key located on the CD's case. ie. Key 1234-56-7890-123
dylanfree
Post by dylanfree »
Thanks for the reply!
Unfortunately the register option is greyed out, as well, so I cannot obtain a license key or even enter one!
My CD key has already been entered, but since I had to reinstall it is now showing the program is a demo now.
Any ideas?
you need to register the software and if you are unable to do that you will need to call on alarm company that works with WP
** copied from other post **
Install the CD
Login = admin password = (blank)
** You will need Internet Access or you will need to License it over the phone **
License: help -> HoneyWell access sytems -> Registration
A web browser will open to : https://www.honeywellaccess.com/ss/index.html
Look for Resources bottom center of page
click: Register products Online
Once licensed use the quick-Start wizard
Quick Start-Wizard, will not work in XP
Install disk is a CD not a DVD
The only problem I have had with installing WinPakPE is if the computer has ANY SQL software installed on it before I start.
